Brief Description: Left wing leading edge deburring
I completed the deburring of the left wing leading edge ribs and joint plate. Then I assembled the leading edge to check for rib to skin fit and skin to spar fit. The spar needed more countersinking for the skin to fit properly. Then I dimpled the wing walk doubler and clecoed the wing walk doubler and wing main skins onto the wing skeleton for a fit check of all the main ribs to main skins.
